March 24, 2016, 23:56 |
VIV simulation - Mesh Update Problem
LRubino
Rep Power: 10 |
Hi guys!
I'm doing a 2D VIV study over a cylinder in Fluent . First , I perfomed analysis of the flow around a static cylinder, and the results were consistent and did not have many problems. For the VIV analysis , I wrote a UDF to simulate the oscilation of the cylinder in cros-flow direction using dynamic mesh and here the problems started . I am using a structured mesh and I'm having the problem of " negative cell volume detected" . Initially, I tried to use the layering method , but it presented many problems. Then I tried using diffusion smoothing method , but the problem persisted . I've thought about changing the mesh to triangles , but I avoid it because the structured mesh shows better convergence. Does anyone have any suggestions of how to deform structured mesh without having this problem of negative volume? Thx! |
March 25, 2016, 09:57 |
#2 | |
1. Use concept of two domains : inner and outer. 2. give motion to whole inner domain 3. Use re meshing option with appropriate settings. this is very important Alternatively you can use 1. 6DOF rigid body solver or 2. Two way FSI |
March 25, 2016, 12:00 |
LRubino
Rep Power: 10 |
Hi!
Thanks for reply. I'm using 6DOF rigid body solver. The suggestion is to create two domains. Assign movement to the domain closest to cylinder using the same UDF i'm using for the 6DOF moviment of the cylinder? So, the inner domain moves together with the cylinder? The outer domain assign deforming using smoothing and remeshing methods? Here is the mesh that i'm using. Thanks! mesh 1.jpg |
March 26, 2016, 14:40 |
LRubino
Rep Power: 10 |
I tried again to perform the simulation and the problem persists.
The mesh is deforming near the inner domain, even using smoothing diffusion method with diffusion parameter = 3. I read in the Fluent Users Guide that higher values of diffusion parameter preserve larger regions of the mesh near the moving body and cause regions away of the moving body to absorb more of the motion, but this is not happening. I'm doing something wrong, but I dont know exactly what. |
March 26, 2016, 21:35 |
#6 | |
July 1, 2016, 05:32 |
Daban M. salih
Rep Power: 10 |
i am doing similar problem and i had your problem i resolved it with small "max itteration/timestep" and a diffusion value of 1 for remeshing.
how did u write your UDF file can you share it? |
dynamic mesh, dynamic mesh;, fluent, fluent - udf, negative volume error |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
2D Single Bladed VAWT Simulation with Sliding Mesh Problem | peter go | FLUENT | 8 | September 8, 2015 11:39 |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 09:45 |
Simulation Mesh Problem | Ed_89 | STAR-CD | 1 | March 13, 2013 13:14 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
