jigneshrohit
Rep Power: 10 ![]() |
hello , if the water flows in horizontal pipe and inlet velocity and inlet temperature is given in fluent , then how and where to see the outlet temperature of water.
if i am see the contours of temperature and static temperature and compute it; whether the temperature display in max. temperature is my outlet temperature ? suggestion needed. currently in laminar flow of water inlet temperature i gave is 303 k and static and total temperature is also 303 k. is this because there is no heat flux on pipe wall? and if i give the heat flux , and do compute in contours ; will it give to me outlet temperature but i dont know how to see????????????????? |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Pressing compute will calculate the minimum and maximum temperature in the region selected. By default it will calculate the max-min over the global domain until your deselect the check box so that it computes only over the domain you have selected. Do so, and you can get the min-max tempeature at your outlet (of course you have to select the surface).
Otherwise, you can also use a report to calculate area or mass weighted averages of the static temperature. And obviously you need a heat flux or the temperature will stay constant. |
fluent 12 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Strange Results at Tank Outlet with InterFoam | mgdenno | OpenFOAM | 18 | November 28, 2019 23:05 |
flow controled by outlet temperature | soonic | OpenFOAM Running, Solving & CFD | 0 | January 30, 2012 09:07 |
outlet temperature | sarajags_89 | OpenFOAM | 6 | November 15, 2009 10:34 |
Fully developed temperature profile for square cross section duct at outlet | balkri | Main CFD Forum | 0 | October 5, 2009 11:06 |
