How to model a rotating heat source in Ansys Fluent?
Old   March 22, 2016, 10:32
Default How to model a rotating heat source in Ansys Fluent?
beastieboys6 is on a distinguished road
Hello, everyone. I'm working on a typical conjugate heat transfer problem.
The geometry is basically coaxial tubes. Cooling water (blue region) flows outside a solid region (brown region) that is heated somewhere around the center on the inner surface by a rotating heat source. The heat source is similar to laser and the component allowing the heat source to rotate is not included in my model. In other words, all the geometry in my model is static but the heat source is rotating.
I am planning to run the simulation using Ansys Fluent. I'm considering using sliding mesh or UDF. But if I understand correctly, applying sliding mesh in such a case will mean some parts of the geometry are actually moving, which might in turn affect the flow fields near the solid surface. Is that correct. As for UDF, I was wondering if there is any tutorial on this topic.
Any comment or advice will be highly appreciated.
beastieboys6 is offline   Reply With Quote
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 13:40
