Total Heat imbalance even if solution 'converged' |
March 22, 2016, 10:20 |
Amit Kunte
Rep Power: 11 |
Hi friends ,
I am simulating a gaseous combustion problem, and the solution seems 'converged' if the residuals (energy:<1e-09 and all other: <1e-07) and the 'total sensible heat transfer rate' across all surfaces ( imbalance < 0.1 Watt) is considered. But the Total heat transfer rate refuses to converge even after running an extra 100000 iterations after reporting the above values. I have made the walls of the reactor adiabatic (to simplify things) but the difference between total heat input thru the velocity inlet and the total heat outlet through the pressure outlet is still substantial. (The exit temperature of the straight channel combustor does not match with the adiabatic flame temperature at the same conditions) I have already done a lot of simulations since 8 months ensuring that the above criteria are met but ignoring the 'total heat transfer rate' balance and there is a disparity in all the results. This has brought the veracity of all my past simulations under question. I have attached a screenshot of the 'FluX REPORT'. Please can someone address this problem??!. Also, heat seems to be losing near the velocity inlet , even though the thermal BC there is a constant 300K( and constant inlet velocity normal to inlet). Turning inlet diffusion off does not change the result much. |
March 30, 2016, 17:39 |
Amit Kunte
Rep Power: 11 |
Can anyone help here??
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
Total heat release rate - variation not expected | Bufacchi | OpenFOAM Running, Solving & CFD | 14 | May 15, 2020 07:35 |
Unable to get converged solution using SimpleFoam | jr33 | OpenFOAM Running, Solving & CFD | 6 | December 12, 2016 05:48 |
Difference between Total Heat Source and Volumetric Heat Generation? | sieginc. | STAR-CCM+ | 1 | March 26, 2013 04:20 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 08:51 |
