How to set heat transfer coefficient and wall temperature
Old   March 21, 2016, 04:45
Default How to set heat transfer coefficient and wall temperature
Jordi Pina
jpina is on a distinguished road
Dear all,
I’m carrying out a conjugate heat transfer coefficient, where I have a meshed solid and a meshed fluid in contact.
I want to set a heat transfer coefficient of 5000 W/m^2/K and a fixed wall temperature. However, in the convective heat transfer options, eventhough I can choose the heat transfer coefficient, I cannot set the wall temperature, but the free stream temperature.
How could I set a fixed wall temperature and a heat transfer coefficient?
Thanks a lot.
jpina is offline   Reply With Quote
Old   March 21, 2016, 09:47
Jordi Pina
For a fixed temperature BC,
(7.3-47)
where
=fluid-side local heat transfer coefficient=wall surface temperature=local fluid temperature=radiative heat flux
But I want to set myself the hf value! Instead, ANSYS help says:
"Note that the fluid-side heat transfer coefficient is computed based on the local flow-field conditions (e.g., turbulence level, temperature, and velocity profiles), as described by Equation 7.3-54 and this equation in the separate Theory Guide. "
Which is not what I am interested in!
I will appreciate your help... I'm stucked in this...
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
