Turbulence specification at Inlet and Outlet for boiling flows |
Balamuralo
Rep Power: 0 ![]() |
Hi , I am modeling 2D case of impinging boiling flows. k-e model is the one which i have chosen for turbulence model. I do not know how to determine the turb. kinetic energy and turb dissipation rate for inlet. Will changing between different turbulence specification methods affect the results much ? Because i am getting vapor fraction in order of 10^-4 but exp result is in order of 10^-2...where could be the problem ? Is it with turbulence specification or something else ?
boiling flow, turbulence specification, void fraction |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
define BCs at inlet and outlet for natural ventilation simulation | jjz2013 | Main CFD Forum | 0 | January 29, 2013 15:50 |
How to define the turbulence intensity and mixing length at an outlet (for k-eps)? | david39 | OpenFOAM Running, Solving & CFD | 6 | February 2, 2011 03:01 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
