March 19, 2016, 10:32 |
Turbulence Intensity
Niels Hawinkel
Rep Power: 10 |
I'm trying to model the drag coefficient on a car.
When i set the Turbulence Intensity to 15% at the inlet and outlet backflow and plot the result, I can see that the turbulence intensity immediatly drops to basically 0% right after the inlet (so it has no influence). The turbulence viscosity ratio is 10 and I use a uniform velocity profile (25m/s horizontal at inlet). How do I solve this? |
March 20, 2016, 12:59 |
Niels Hawinkel
Rep Power: 10 |
up, post boost
March 24, 2016, 06:04 |
Niels Hawinkel
Rep Power: 10 |
up, post boost
March 25, 2016, 14:21 |
Lucky
Rep Power: 66 |
A uniform velocity profile is shear free and therefore has limited capability to produce and sustain turbulence. Thus any turbulence at the inlet will eventually decay and die out (reach 0%). The question is how long of a distance until it decays and this depends on the length scale of the turbulence.
A turbulence viscosity ratio of 10 is extremely (pathetically) mild. This magnitude of the viscosity ratio is what you would expect to see at the edge of a boundary layer (the freestream boundary, where the shear is very small and very little turbulence exists). |
February 3, 2017, 15:24 |
#5 | |
Rep Power: 9 |
Did you find the way to solve this problem? I'm getting the same results when running a 16% turbulence intensity external flow case. Thanks, |
Turbulence Intensity at inlet boudary | egge24 | FLUENT | 1 | October 10, 2015 16:56 |
Turbulence intensity - cross wind on a body | Fabio88 | Main CFD Forum | 0 | May 4, 2015 04:44 |
How to define the turbulence intensity and mixing length at an outlet (for k-eps)? | david39 | OpenFOAM Running, Solving & CFD | 6 | February 2, 2011 04:01 |
High turbulence intensity | wenfengxie | FLUENT | 1 | April 16, 2010 13:00 |
High Turbulence Intensity Problem | bwg | FLUENT | 1 | January 13, 2010 14:09 |
