sharath jallu
Rep Power: 10 ![]() |
for super critical water as working fluid, through out the pressure remains constant (24 MPa) .. so what should be the type to be selected? (pressure based or density based)
And under setup & in materials menu ,what should be selected for density, specific heat from down down list? (Apart from keeping it constant) If possible can any one help me with super critical water complete properties ?? ( viscosity, thermal conductivity) |
M Kashif Tehseen
REFPROP is a software which can provide all properties related to super critical water........
![]() you can create new fluid in fluent or link it to the REFPROP to take values directly. |
sharath jallu
in refprop i got the standard fluid properties but i'm unable to get the super critical water properties.
can u help me with it plz.. ![]() also what should be selected from drop down list of density, specific heat..?? ![]() |
material properties, setup fluent |
Supercritical Water Properties | McKOG | STAR-CCM+ | 2 | November 1, 2019 11:56 |
Constant properties water with variable density as a function of temperature | JuPa | CFX | 4 | November 1, 2014 04:43 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
variable density water | Atit Koonsrisuk | CFX | 2 | July 24, 2003 03:07 |
