March 16, 2016, 05:00 |
Vertical Axis Wind Turbine
Prakhar
I am working on CFD of a vertical Axis Wind turbine. I placed the blade in a rectangular enclosure with one side as inlet,opposite as outlet and the rest as wall. I did a transient analysis by rotating the blade from 30 to 150 degrees along the direction of the wind at a speed of 5 m/s where blade is of the dimensions 1.6 feet * 0.5 feet.
When I give 101325 Pa in the reference pressure location of reference values from inlet, I get 1000 Newtons of air force on the blade. When the reference pressure is given 0 the force on the blade is giving 130 Newtons of force. Which of the above parameter is right? What is the prominence of Reference Pressure in the Reference Values of Fluent? |
pressure based, reference -values, windturbine |
Vertical Axis Wind Turbine | f.gig | Fidelity CFD | 4 | May 30, 2014 10:57 |
Vertical Axis Wind Turbine | atorninc | Main CFD Forum | 3 | March 6, 2013 05:38 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 04:14 |
Reversed flow in Vertical axis wind turbine | Anonymized_JL1 | FLUENT | 2 | April 11, 2012 04:13 |
Vertical axis wind turbine in NUMECA | ArslanOZCAN | Fidelity CFD | 2 | July 21, 2011 06:04 |
