Problem with using MRF Model for verical axis wind turbine Model
Old   March 15, 2016, 03:01
Default Problem with using MRF Model for verical axis wind turbine Model
Raj
rgunjegaonkar@gmail.com is on a distinguished road
hello everyone here,
i m doing VAWT simulation for Torque Value by creating interface between rotating and stationary domain in Fluent.
After creating interface it also creates additional wall-Fluid-wind & wall-Fluid-MRF.
When say check case it shows comment-"Review wall motion. Stationary wall motion relative to adjacent cell zone detected."
BCS Used:
Fluid MRF: Rotating Domain
Relative to cell zone-Absolute-Angular Velocity 10 rad/s(95 rpm)
wall blade-Stationary Wall
Fluid Wind-Stationary Domain
Inlet-5 m/s,
Outlet- 0 Pa
I am confusing about how to overcome this problem.
help me plse.
rgunjegaonkar@gmail.com is offline   Reply With Quote
Old   March 15, 2016, 04:59
Cees Haringa
CeesH is on a distinguished road
Hello Raj,
Do you have any walls that are located inside the rotational part of the domain that are set to be a moving wall, but with a velocity of 0 (with respect to the domain it is in)?
CeesH is offline   Reply With Quote
Old   March 15, 2016, 06:49
Raj
Originally Posted by CeesH View Post
Hello Raj,
Hello sir,
As i said it creates two extra wall on both the side after creating interface.
I. interface-interior-1-1
II. interface-side1-wall-int_1 (Fluid MRF side)
III. interface-side2-wall-int2 (Fluid Wind Side)
I tried also selecting that wall with rotating wall with zero velocity(Relative to cell zone) but it shows same message after clicking Check Case.
Old   March 15, 2016, 06:57
Cees Haringa
can you show a picture of these walls? i am not quite sure what you mean
Old   March 15, 2016, 07:32
Raj
plse find attached pictures
Old   March 15, 2016, 07:43
Cees Haringa
And I guess these walls are not supposed to be there, right? (do you see them when you display your wall meshes?)
Did you create your interface as a coupled wall or something like that?
Old   March 15, 2016, 07:53
Raj
after selecting coupled wall again it creates some additional walls...plse find attached pictures for reference.
really sorry for my bad english.
Old   March 15, 2016, 07:58
Raj
u r right sir...these wall should not be there...also no interior option is available in boundary condition for the same.
Old   March 15, 2016, 08:00
Cees Haringa
They may occur if you set the interface as coupled walls, did you do so? If so, remove the interface and re-create it, setting no coupled wall or so.
Old   March 15, 2016, 08:06
Raj
I did the same.
also it shows note in console window after creating interface
"Note: Slitting sliding interface zone 43 into a coupled wall.
creating interface-wall1-1-1-shadow
Info: Interface zones overlap for mesh interface interface.
This could adversely affect your solution."
Old   March 15, 2016, 08:15
Raj
i dont no more about coupled wall in interface window...but i think we use coupled wall when there is transfer of energy from one fluid to other(Non Mixing of Fluid).
Old   March 15, 2016, 08:25
Cees Haringa
yes, but I guess you want fluid flow to pass through the interface, so you don't want a coupled wall. Are both sides of the interface well connected? Or is there a gap between them? How did you separate the rotating and stationary zone in your geometry design?
Old   March 15, 2016, 08:33
Raj
actually mesh pattern on both side interface wall is different.Should be there mesh connectivity between the two sides of interface.
Old   March 15, 2016, 08:37
Cees Haringa
As far as I know that is not necesarry, I've done some runs with non-matching interfaces and that worked fine. But they do have to be connected; there may not be a gap between the sides.
Old   March 15, 2016, 22:41
Raj
is there any minimum criteria for mesh element matching on two interface wall
Old   March 16, 2016, 05:28
Cees Haringa
Not that I know of.
Can you perhaps send me your .msh file? I can take a look at it. (if you send it via mail, please do zip it, otherwise outlook won't open it).
I'll send you my details
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) tony00 FLUENT 11 July 23, 2018 07:13
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 15:07
[ANSYS Meshing] wind turbine simulation meshing problem maxwell94 ANSYS Meshing & Geometry 0 January 26, 2014 14:06
Vertical axis wind turbine - GGI problem Piotr Zwolinski CFX 1 January 12, 2014 07:01
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 05:09
