Windows 7, 10 and Ansys 16 and Ansys 17
Like Tree5Likes
Old   April 28, 2017, 10:57
Default Unable to start the geometry editor.
  #21
Getachew Neme
Getachew Neme is on a distinguished road
I Installed Ansys 17.0 on new machine (Dell Precision Tower 5810, Windows 10 Pro, 64 bit system). I installed the Ansysy successfully and I couldn't run the Design Modeller due to the error "Unable to start the geometry editor". Please, any help to fix my problem?
Kindly request,
Getachew Neme is offline   Reply With Quote
Old   August 14, 2017, 18:07
Thiago
tsl84 is on a distinguished road
mehaque101 ,
Did you solve the problem? I have the same problem, but with ansys 18.
tsl84 is offline   Reply With Quote
Old   August 14, 2017, 18:09
Default same problem with ansys license manager release 18
  #23
Thiago
Originally Posted by mehaque101 View Post
I am also trying to install ansys 17 on win 7 pro and getting this error,
error: problems were encountered while attempting to start the following process ansysli_server.exe, ansysli_monitor.exe, ansyslmd.exe
There is no anti virus program on this machine and i added exception for the above files in window firewall.
Any help will be greatly appreciated.
Old   August 14, 2017, 21:01
SJSW is on a distinguished road
[GeomEditorTimeOut:DMAddin] Unable to start the geometry editor.
There is the same question posted, but I don't know if it's solved. you can try it and respond the results in the thread.
SJSW is offline   Reply With Quote
Old   August 14, 2017, 22:21
Lucky
v18 should work in Win7 64. Honestly just double check if you installed everything correctly. See if launching the license utility with admin settings help. Make sure you've installed pre-reqs and you have Wiindows Service Packs.
Did you have a previous version of Fluent installed? Make sure you've followed the instructions to remove the old license manager. Uninstalling Ansys doesn't remove the license manager. You can quickly check your environmental variables to see if old information is there.
For debugging I recommend to only tinker with the ANSYS License Management Center because it's a standlone process. Don't do anything weird like trying to launch workbench of design modeler or anything. If the license manager processes does not launch, nothing will work.
Old   August 15, 2017, 03:12
Getachew Neme
mehaque101 ,
Dear,
Yes I fixed the problem as of the following:
C:\Program Files\ANSYS Inc\v170\ProductConfig
I configured all the important programs and then restarted my PC. It worked after then.
yanwooyan likes this.
Old   August 15, 2017, 11:49
Thiago
Yes, I was able to install in my notebook that has win7, but in this one that has win 10 pro is not working ... before installing I uninstalled everything that was old and installed all the pre requisites ... I no longer know what to do ... I've tried everything ... I think it's something related to win 10 ... but I do not know how to solve it ..
Old   August 15, 2017, 11:51
Thiago
Originally Posted by Getachew Neme View Post
Dear,
thanks, but this did not work for me.
Old   August 15, 2017, 12:59
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
install fresh copy of windows.
Far is offline   Reply With Quote
Old   August 15, 2017, 21:09
Lucky
Uninstalling Fluent/Ansys does not remove the license manager. There simply is no uninstaller for the license manager. You can only pray that installing the v18 license manager overwrites all necessary settings, but this is not always the case. The old license manager must be removed manually. Which leads me to repeat Far's post...
Also, you really should be contacting Ansys support. After all, you or your company has already paid good money to use their stuff. Why did you spend all this money if you can't even install the darn thing? The only thing you need to get support is the customer ID, which you should always have.
Old   November 28, 2020, 20:06
Default ProductConfig works for me.
  #31
anonim
yanwooyan is on a distinguished road
Dear,
Works well for me, thanks .
Note :
version 16 on Windows 10 Pro 19041.630. Likely cause are OS upgrade from Home to Pro and some following updates.
yanwooyan is offline   Reply With Quote
