March 12, 2016, 08:38 |
TKE budget estimation by k-epsilon model
Prasun Dutta
Rep Power: 12 |
Hi
I am working on turbulent pipe flow problems, three dimensional and I want to plot total turbulent kinetic energy budget in different axial and redial direction in a pipe bend flow. Reynolds stress transport equation can be defined as: ∂k/∂t= Pk + εk + πk + Dk + Tk − Ck where (i) Production (Pk) = −<uiuj> ∂Ui/∂xj (ii) Dissipation (εk) = −ν <∂ui/∂xj∂ui/∂xj> (iii) Pressure diffusion (πk) = −1/ρ ∂(<pui>)/∂xi (iv) Viscous diffusion (Dk) = (ν/2) ∂^2(<uiui>)/∂xj^2 (v) Turbulent diffusion (Tk) = −(1/2) ∂<uiuiuj>/∂xj (vi) Convection (Ck) = <uj>/2 ∂(<uiui>)/∂xj Now due to lack of computations resources I can not affort LES. So if I perform transient simulation with k-epsilon model and using the fluctuation data (ui, uj, uk) is it logical to get TKE budget because it is well known that k-epsilon turbulent model is solving the turbulent kinetic energy (k) and turbulent dissipation (ε) using its modeled transport equations and coefficients. Thanks .. |
March 12, 2016, 11:25 |
Lucky
Rep Power: 66 |
Why can't you solve the k-epsilon model in steady state and just get the turbulent kinetic energy from that? I am not sure what you hope to achieve by running a transient k-epsilon model.
I also don't get where velocity fluctuations come into play. Are you sure you can get fluctuations from a k-epsilon model? You've written down a time-averaged equation (a RANS/URANS equation). Because of separate of time-scales you wouldn't be able to get velocity fluctuations from RANS. A time-accurate k-epsilon is slightly more expensive than a time-accurate LES because of the additional transport equations being solved (for k and epsilon) whereas LES solves only the three momentum equations. |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
TKE budget equation in LES | doctorWho | Main CFD Forum | 3 | March 12, 2014 11:27 |
Low Reynolds K Epsilon Launder Sharma Model Functions Doubt... | Ruonin | Main CFD Forum | 17 | February 17, 2014 09:52 |
Jump in epsilon values near the wall : low re k-epsilon model | malaboss | OpenFOAM Verification & Validation | 1 | February 1, 2013 16:36 |
Help regarding K Epsilon model | go2saqi | Main CFD Forum | 2 | January 23, 2012 11:59 |
