Temperature Limited Problem
Old   March 11, 2016, 08:28
Default Temperature Limited Problem
tuna
tuna is on a distinguished road
Hi everyone,
I have a problem about "Temperature Limited Problem". BC's of geometry are inlet=308 K and surface temperature of wall is 293 K. But some point temperature is nearly 2437K to 5000K. How can I solve this Problem ? Anyone can help me ? I tried lots of methods. For example I increased mesh elements. 2000000 is enough but increased 4000000 mesh elements and I changed convergence criteria and changed solution methods but I can not find anything. Outlet BC is pressure outlet and default of program of specification method under Momentum title gives intensity and viscosity but my solution model is k-e therefore I changed intensity/viscosity to k-e but this method did not help me. Anyone can help me ? (Note: inlet and outlet hydraulic diameter of my geometry is not same.)
Thanks for helps.
Best wishes
tuna is offline   Reply With Quote
Old   March 11, 2016, 17:06
`e`
`e` is on a distinguished road
What is the geometry and where is this peak temperature found? Perhaps include a temperature contour plot.
What are the initial conditions and is the flow steady or transient?
`e` is offline   Reply With Quote
Old   March 12, 2016, 08:53
tuna
The initial condition is V=2.74 m/s and Temperature is 308 K and flow is steady ?
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Problem in modified pisoFoam with temperature equation + thermophysical model Matt_B OpenFOAM Programming & Development 17 November 7, 2019 10:23
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
the problem that gradually change of temperature contour in coal gasification bluenail FLUENT 0 November 10, 2014 03:41
Problem when adding temperature to interFoam houkensjtu OpenFOAM 4 November 5, 2012 03:35
