weird number in my results: -1.000000020040877e+20 why?
Old   March 10, 2016, 04:42
Default weird number in my results: -1.000000020040877e+20 why?
navid
ndabir is on a distinguished road
Hey all,
I am doing a moving wall simulation inside water. I am expecting to see pressure waves inside water. Good news is the simulation works fine and I can see the waves.
However, bad news is while I start to save pressure values at different points inside water using surface monitors, I get this weird number: -1.000000020040877e+20
This number appears on the console if I activate the console printing option and also appears on the surface monitor files. However, when I stop the simulation and look at the pressure contours, the pressure values are in normal expected range (around a few bars).
So I am confused now. How is that number generated and why? Any experience to how to solve it?
Again I should mention the simulation works fine. The residuals are good and there is no problem during simulation running. Just that pressure values sometimes (not always) are printed as this -1.000000020040877e+20 number instead of the actual number.
ndabir is offline   Reply With Quote
Old   March 11, 2016, 00:20
navid
any ideas?
Old   March 13, 2016, 11:02
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by ndabir View Post
Hey all,
Flow is incompressible and you are applying moving wall with closed domain > This will always be problem.
Far is offline   Reply With Quote
Old   March 14, 2016, 13:42
navid
I am considering the flow to be compressible. And as I said there is no problem in the simulation results itself. The problem is coming from how fluent writes the numbers in the surface monitors. The actual numbers are OK when I check them in the contour plots but when I write them in surface monitors, it shows them as -1e+20.
Old   March 14, 2016, 14:05
Far
Sijal
Can you please share your screen shots of these results and how you are setting them in fluent?
Old   March 14, 2016, 14:22
navid
Please see the attached picture. This is the surface monitor of pressure at a point in water. As you can see sometimes the written pressure is the actual number (around -52000 Pa) and sometimes the written pressure is -1e+20.
Old   March 18, 2016, 18:24
navid
Does anybody know why fluent is writing numbers as -1e20?
Old   March 18, 2016, 20:59
Far
Sijal
which monitor you are observing? how you had defined that one? any details of what you are setting up?
[ImmersedBoundary] Immersed Boundary Method in OpenFOAM-3.1-ext miladrakhsha OpenFOAM Community Contributions 106 July 3, 2023 11:26
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
Stable boundaries marcoymarc CFX 33 March 13, 2013 07:39
