March 9, 2016, 17:47 |
Heat Transfer Problem
Daniel Shaw
Rep Power: 11 |
I'm relatively new to CFD and I think I have bitten off more than I chew. I'm trying to simulate the flow in a vertical smoker: I have two velocity inlets (I have also tried these as pressure inlets too - gauge 0), a pressure outlet (gauge 0) and two symmetry constraints. The fuel is set up as a heat flux (169635 w/m2) and the walls have mixed thermal properties. I'm using the realizable k-e model with enhanced wall treatment, bouyancy effects are on (gravity too), radiation is DO. Air as an incompressible ideal gas. My results aren't very realistic, they show the fuel to be at 300C+ but the air next to it at 10C... Please help. |
fluent 15.0, heat, heat flux, heat transfer |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 19:53 |
Heat Transfer Problem Help | JB | FLUENT | 2 | October 18, 2006 19:54 |
