March 9, 2016, 05:43 |
Speed Velocity Vector
Anonymous
HI..just want to ask your opinion on how to solve this.
the case is, i have run a simulation for a basement to see the speed velocity vector of the air, from the fresh air & exhaust duct. the contours also shows good result but on closer view, there is no velocity vector from the duct. I've tried to reset the setting, still no good. |
March 9, 2016, 06:17 |
Are you plotting contours or vectors? They're two distinctly different things in Fluent. If contours look good (logical, expected), then you should have no problems with vectors.. as long as you're actually displaying vectors.
If you're in need of some free quality CFD video tutorials - check out SiriusCFD @ YouTube Last edited by scipy; March 11, 2016 at 17:29. |
March 10, 2016, 05:40 |
Anonymous
Im trying to plot the speed vector.
The contour is good, but on close inspection (vector), it seems as the fresh air duct has no air coming out from the duct. |
March 11, 2016, 07:22 |
Did you try doing a flux report on the face of the inlet? Try to do a mass flow rate report and see if it's a positive value.
Also, a screenshot of the vectors and the problem might help.
If you're in need of some free quality CFD video tutorials - check out SiriusCFD @ YouTube Last edited by scipy; March 11, 2016 at 17:30. |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
How to show vector of Axial velocity in 2D plane? | Eakarach | FLUENT | 6 | March 14, 2014 17:47 |
How to plot average velocity vs direction vector in fluent | hamidhamidhamidhamidhamid | FLUENT | 0 | January 1, 2013 15:13 |
Buy software for draw vector velocity | Yassin | FLUENT | 0 | January 18, 2006 12:35 |
Vector field of space averaged speed | nicolas | FLUENT | 0 | February 10, 2005 12:16 |
