The backflow hydraulic diameter of a double volute centrifugal pump
Old   March 3, 2016, 21:51
Default The backflow hydraulic diameter of a double volute centrifugal pump
Have a nice time!
Ahmed Saeed Mansour is on a distinguished road
How can I calculate the backflow hydraulic diameter of a double volute centrifugal pump to enter it in the boundary conditions in Fluent?
https://www.google.com.eg/search?q=d...u0CvytI4X9M%3A
Ahmed Saeed Mansour is offline   Reply With Quote
Old   March 5, 2016, 20:55
Lucky
What you need to specify is the turbulence in case there is reverse flow. It may help to think of it as your k and epsilon or k and omega.
Note that if there is not any reverse flow (which I don't think there should be in a pump) then the backflow properties will never be used except at intermediate iterations.
Old   March 7, 2016, 06:34
Have a nice time!
I know that the hydraulic diameter is 0.015 m but I don't know what is the formula to know how to calculate it?
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 04:34
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 07:09
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
