Rotating Brake Disc, rotational velocity function
Old   February 29, 2016, 06:58
Smile Rotating Brake Disc, rotational velocity function
Christoph
chrisnied is on a distinguished road
Hello CFD Online members
I'm new in ANSYS Fluent. I'm trying to calculate the flow around a rotating disc. For this purpose I have received an EXCEL table. There you can find lots of time points [s] and the corresponding rotational velocity around the z-axis [rad s^-1]. Now I want to use the data to create a function, so FLUENT selects automatically the "right" velocity, based on the time point.
How can I do it?
It would be nice, if you could help me.
greetings
chris
chrisnied is offline   Reply With Quote
Old   March 1, 2016, 21:16
Edoardo
edd313 is on a distinguished road
You need to write a UDF. I am not sure but you may use DEFINE_ZONE_MOTION. You should definitely check the UDF manual to find a solution to your problem anyway.
edd313 is offline   Reply With Quote
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY everest20 FLUENT 1 July 13, 2015 09:35
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
Heat convection into a Disc brake Robin Windram FLUENT 0 February 20, 2009 08:03
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
