Fluent Problem-Two phase Poiseuille flow between two plates |
February 24, 2016, 17:29 |
Hope
Rep Power: 14 |
I am trying to use Fluent to solve a simple problem, the two phase flow between two parallel plates, for my course project. The physical model is described here: http://www.chemecomp.com/poiseuille_immiscible.pdf Or here: http://test.interface.free.fr/Case14.pdf I am trying to get the same result numerically. My mesh is like this: mesh.JPG 2D planar steady state problem. I am using VOF and Laminar models. Didn't change setting. I have two fluid with same density but different viscosity. I think the result should not be a function of density. I meshed the interface. I tried on "coupled wall", but the velocity is set to 0 at interface. I don't know how to make the wall is shear stress balanced. Without "coupled wall", the velocity is continuum at the interface, but fluid will cross the interface, which is not what I want. Like this (contour of void fraction): voidfraction.JPG My question is, what should I do to make an interface in the middle such that the two fluids can't cross it, but balanced with shear stress? Thank you very much. hopehope |
fluent, interface, poiseuille, two-phase |
Discrete Phase Model, outlet mass flow rate does not fit | edu_aero | FLUENT | 29 | February 3, 2020 09:38 |
VOF method in fluent for two phase thermosyphon flow | ic3lemon | Fluent Multiphase | 1 | November 1, 2016 05:40 |
modeling cross flow problem in fluent | kbaker | FLUENT | 0 | September 25, 2015 14:52 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
Two phase flow - Euler in Fluent | MartinP | Main CFD Forum | 1 | November 3, 2006 15:15 |
