Swirl ratio fluctuates
Old   February 24, 2016, 03:24
Default Swirl ratio fluctuates
Gomathi shankar
tgsankar is on a distinguished road
Iam doing an analysis of port flow in Ansys Fluent. In that i need to calculate the swirl ratio at a plane. For that i created a field function as follows:
(x*Vz-z*Vx)/(x*x+z*z)
I created a surface monitor for mass averaged swirl ratio at a required plane and also for mass flow rate at outlet.
The problem is that the swirl ratio does not converges even if the solution is converged. The mass flow rate converges. If i see the plot of the mass averaged swirl ratio at the plane it keeps on fluctuating.
The simulation conditions are
inlet: pressure inlet atm pressure
outlet: pressure outlet (-2451.5 Pa)
Model: Realizable k-epsilon
I need to know that the problem is with the field function or with the simulation setup. Have anyone experienced similar situation?
Thanks
tgsankar is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
measure of swirl ratio cnaksoy STAR-CD 0 August 31, 2014 12:04
Swirl ratio failure in remeshing in CFX a_cucen CFX 15 March 4, 2013 17:28
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 08:42
swirl ratio reduction sijin james Siemens 3 May 10, 2007 07:12
