February 23, 2016, 11:58 |
Help with boundary conditions!
haze
Rep Power: 10 |
Hello forum,
I am looking to design a heat exchanger. So the heat exchanger will have 2 bodies , one is a cylinder in which water will be maintained at a constant temperature and into this volume will be inserted a helical coil (2 nd body)through which our fluid (which is to be heated) will pass. What kind of boundary condition should I use for outer body . Thank you. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 10:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
