February 23, 2016, 01:10 |
pressure coefficient greater than one
ajay varma
Rep Power: 10 |
Im using fluent for analyzing flow on a 2d wing. my flow speeds are around 30m/s . solver settings are : pressure based, k-w SST, boudary conditions are
velocity inlet , pressure outlet,top(wall),bottom(wall),aerofoil (wall). i have done modeling in icem cfd with 7lakh quad mesh and i have used farfield distance for about 5 times of the chord due to computational constraints. i m having problem with increase in the angle of attack.that is pressure coeffiecient value is going higher than that of 1 when i increase my angle to 4 degree. can someone pls help me. |
February 24, 2016, 01:21 |
Lucky
Rep Power: 66 |
Check your reference values. Make sure you have specified the correct reference velocity, length, etc.
April 2, 2016, 02:17 |
ajay varma
Rep Power: 10 |
how should we calculate reference values, if there is any way please kindly specify thank you
fluent 16.0, icem cfd 16.2 |
Pressure coefficient | Giuseppe | FLUENT | 2 | July 26, 2015 03:19 |
simpleFoam - pressure (coefficient) of head shape | GJM1991 | OpenFOAM Running, Solving & CFD | 4 | May 12, 2015 17:15 |
lid-driven cavity in matlab using BiCGStab | Don456 | Main CFD Forum | 1 | January 19, 2012 15:00 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
