February 19, 2016, 04:41 |
Easy way for exporting data from fluent
Regularly I use tecplot 360's "probe data" option to export velocity and pressure data from ansys fluent's CAS and DATA files, giving the X,Y,Z of the point I manage to export data. This time there are more than 600 points to export, I would like to know if there is an easier way for this.
I have prepared an excel file containing the X,Y,Z belonging to the respective nodes to extract data, and I need Vx,Vy,Vz, and Pressure quantities. Thanks in advance. |
February 19, 2016, 05:11 |
Grigoriy Ermolaev
Rep Power: 12 |
May be save the interpolation file? Or you need only for this points?
February 19, 2016, 05:20 |
Thanks for your quick reply
I needx-velocity, y-velocity, z-velocity for specific points. I have already exported an ASCII file and imported it to excel. But seems like in this way I'm having the data for nodes created in the meshing process. tons of data that I don't need. |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 02:47 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
[Commercial meshers] Problem converting fluent mesh | vinz | OpenFOAM Meshing & Mesh Conversion | 28 | October 12, 2015 07:37 |
Fluent crash on writing data file after thousand iterations | Chuck87 | FLUENT | 0 | September 2, 2015 17:17 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
