Dyson Air Multiplier realistic airflow
Old   February 17, 2016, 17:02
Default Dyson Air Multiplier realistic airflow
broberts is on a distinguished road
I'm trying to model air flow from a cross section of a Dyson AM06 in 2D. I'm using Ansys Fluent, k-epsilon, realizable, standard wall fn. The issue is the air flow dissipates too quickly and is not realistic of how far the air does actually travel. Changing the turbulence settings of the inlet doesn't seem to make any difference.
Could anyone advise on this?
Regards,
broberts is offline   Reply With Quote
Old   February 17, 2016, 17:19
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Be descriptive.
Show how exactly you tried to model the case, including a view of the whole computational domain with a description of all boundary conditions.
Show the mesh you used and the solver settings. Steady/transient, number of time steps/number of iterations. What do the residuals look like...
The first problem I see here: if you are going to model this in 2D, you have to use axisymmetric 2D instead of planar 2D.
flotus1 is offline   Reply With Quote
Data Center Air conditioning Boundary Condition problem jaypatel OpenFOAM 9 April 8, 2020 16:04
Radiation interface hinca CFX 15 January 26, 2014 18:11
Simulation of air flow in a chamber Issa CFX 3 November 23, 2009 18:16
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 08:04
