How can I find the pressure at distinct locations on a geometry using ansys fluent
Old   February 15, 2016, 13:52
Default How can I find the pressure at distinct locations on a geometry using ansys fluent
J_student is on a distinguished road
I'm currently using Ansys Fluent to model a two phase (GAS-liquid) mixture flowing through a horizontal to vertical 90 degree elbow to determine the pressure fluctuations upstream and downstream of the elbow.
Although I've been able to get contours depicting the expected results.I'm not sure about how to get the pressures at distinct locations on the geometry.
Is this even possible? If yes is there anyone who can tell me how this is done?
Thanks in advance
J_student is offline   Reply With Quote
Old   February 15, 2016, 14:53
B_Kia
HyperNova is on a distinguished road
hi, u have solved the problem numerically which means there is answer for every single point in your domain. by building points it is possible to access the required data. good luck
HyperNova is offline   Reply With Quote
Old   February 16, 2016, 01:17
Lucky
Create probes and monitors are your desired locations. You can create points, lines, planes, etc.
Old   February 29, 2016, 17:11
Thanks for the responses however I'm new to ansys fluent. If it isn't too much to ask can you please direct me to a source which shows exactly how to create points,lines.
Thanks in advance
Regards J_student
[ANSYS Meshing] overlapping geometry in Contact Regions in ansys fluent tj343 ANSYS Meshing & Geometry 20 April 29, 2020 11:39
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
How do I find convergence in ANSYS FLUENT? Deadpretzel FLUENT 0 April 14, 2014 22:02
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 15:32
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
