turubelnce model in ansys fluent
Old   February 15, 2016, 09:32
Default turubelnce model in ansys fluent
sa har
sa har is on a distinguished road
I try to simulate natural convection in channel that has rectangular fins in ansys fluent.i use boussinesq model but i dont know which turbulence model is appropriate for it.
1.k epsilon model with wall function (y+>30)
2.k epsilon model with enhanced wall treatment(y+=1)
3.standard k omega (y+=1)
4.sst k omega(y+=1)
which model is good for channel with fins?and how can i reach to intended y+?
when i calculate y+,i should choose one of the turbulence model or choose one it and try to make a fine mesh. which of this way right?
sa har is offline   Reply With Quote
Old   February 16, 2016, 01:23
Lucky
Make sure you are supercritical, it's fairly difficult to achieve turbulent flow in a natural convection problem. You generally need more than 1m of length to reach the critical Reynolds number.
The k-epsilon with enhanced wall treatment and kw-sst are fairly reasonable general purpose models.
You need a sufficiently fine mesh to achieve a desired y+. You do not know y+ ahead of time and you should try the calculation a few times to see what y+ you get from your solution, and then update your mesh finer/coarser as necessary.
The actual value of y+ will depend on the solution and also the turbulence model used (you'll get different y+ using different turbulence models).
LuckyTran is online now   Reply With Quote
Old   February 16, 2016, 03:16
sa har
thanks alot foryour answer.
you are right,my channel length is more than 1 m and rayleigh number more than 1*10^9 then flow is turbulent.(i solve problem with steady state assumption)
if i use sst k-omega,should be y+ less than 1? a friends said to me that i cant use enhanced wall treatment (k-epsilon) when channel has fins is it right?
Old   February 16, 2016, 10:19
Lucky
SST needs a fine mesh. Otherwise it is equivalent to running a high Reynolds standard k-epsilon model.
The y+ does not have to be 1, what's more important is getting a sufficient number of points to resolve the boundary layer with at least 1 or 2 points in the linear regime. You can have y+ 2 or 3 or 4 and still get great results.
"can't" is a strong and one of the most biased words to use in modelling. You "can" use it, just click the stupid button in Fluent. Maybe your friend can justify why other models are not appropriate. You may ask someone and they will tell you that you cannot model real substances as a fluid with locally uniform properties. Then what do you do? Give up?
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
Ansys Fluent Turbulence Model wall function sr71bb ANSYS 0 August 13, 2015 16:57
gambit in Ansys FLuent 13 saharesobh FLUENT 0 August 1, 2012 16:30
how can export model from fluent to ansys abcd19 ANSYS 0 June 18, 2011 16:15
ansys fluent les model bene Main CFD Forum 0 June 7, 2011 11:45
