Supersonic (Compressible) Inlet Boundary Conditions
Old   February 12, 2016, 17:42
Default Supersonic (Compressible) Inlet Boundary Conditions
Supersonic is on a distinguished road
Hi, can anyone help me? I am trying to model a supersonic inlet to a wind tunnel. According to the user's guide, I am supposed to use a pressure-inlet boundary condition. I am trying to model total pressure of 1.2 MPa, static pressure 82 kPa, total temp 1980 K, and Mach 2.5. When I use the pressure-inlet, there is no where to specify Mach number. When I run the simulation without it, the inlet appears to be closer to 0.5 Mach. What am I doing wrong? Thank you!
Supersonic is offline   Reply With Quote
Old   February 13, 2016, 13:43
Lucky
You do not specify Mach number explicitly but by specifying the total and static pressure. You probably didn't specify the static pressure.
Specify the stagnation pressure / total pressure as 1.2 MPa.
Specify the stagnation / total temperature as 1980 K.
Specify the supersonic / initial pressure as 82 kPa.
Just remember that all pressures are gauge pressures. So set your operating pressure and pressure inputs accordingly.
Old   February 13, 2016, 18:25
Hi LuckyTran,
Thank you for replying, unfortunately, I have done all of that. I set those as the gauge pressures and set operating pressure to 0 to make them total pressures. When I do this, in inlet Mach number is about 0.5. Can you think of anything else I may be doing wrong? Thank you for the help!
Supersonic
Old   February 13, 2016, 19:18
Lucky
Make sure for your pressure inlet you have specified two pressures (the total pressure and the supersonic static pressure) and total temperature.
The other thing to check are your other boundary conditions. Make sure you have the correct downstream conditions to allow a supersonic flow.
Old   March 30, 2016, 13:09
Everything you said was correct. However, you also need to select "Use Specified Initial Pressure on Inlets" under "Solution Initialization" then "More Settings..." to get this to work. It took me 1.5 months to figure this out....
Old   October 3, 2017, 15:41
Default Same simulation convergence problem
Anurag Arya
anuragarya is on a distinguished road
I am having convergence problem when I am doing exactly similar type of problem. I am ending with very large mach number at upstream at some point locations (singularity are coming). I am amateur in CFD, Pls help. Thank you for providing initialisation technique.
anuragarya is offline   Reply With Quote
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Two boundary conditions at inlet syavash OpenFOAM Running, Solving & CFD 1 June 12, 2015 11:09
Inlet Boundary conditions for pressure driven flow in DSMC Jesgonse OpenFOAM Programming & Development 5 October 3, 2014 10:52
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
