Is there a way to access the gradient limiter in Fluent ?
Old   February 9, 2016, 08:38
Default Is there a way to access the gradient limiter in Fluent ?
Jim
CFDYourself is on a distinguished road
Hi there,
I've been struggling with something for several days, and I thought it might be worth asking here in-case someone with more experience can help me out.
I'm interested in getting access to the gradient limiter ('psi' in the equation in the link).
http://www.afs.enea.it/project/neptu...th/node369.htm
There should be a value of 'psi' calculated & stored in every cell each iteration. I'm interested in extracting this data and plotting it, so that I can show where psi is close to zero and where psi is close to one in my model. Psi should be stored in every cell, but I can't find any way to access that data directly.
So rather than accessing psi directly, I've been trying to access it using the "gradient"(G) and the "reconstructed gradient"(RG), which are available to access. My thinking is that the RG/G should give me psi, because psi*G = RG; that's what RG is.
I've tried doing this in two ways: one using a UDF and the data access macros C_K_RG(c,t,[0]) C_K_G(c,t,[0]) {or whatever transported variable}, and then saving this result to a user defined memory slot. The other using the "custom field function" in Fluent to do the same calculation. I'm dividing the component vectors because I know if I divide one vector by the other, I'll likely get a vector for psi where I expect a scalar.
The problem I have is the answer I get, in both cases, isn't the answer I want. I expect psi to be a scalar, between 1 and 0. I do get an average value of 0.9ish {good}. But the maximum and minimum values are in the tens-of-thousands {bad}.
Anyway, I'm at an impasse with it. My question is:
(a) is what I've done right or wrong ?
(b) is there an easier way, say, to access psi directly, say through UDF or Scheme ?
Many thanks,
Jim
PS: it's worth noting I am using the "keep temporary solver memory from being freed?" option in Fluent to access the gradient data, I'm using the UDF from the manual to check the gradients I want to access are available, and I seem to be getting similar answers between the UDF and the custom field function.
CFDYourself is offline   Reply With Quote
Old   February 16, 2016, 06:49
Jim
Hi, thought I would bump this thread, as I'm still having this problem.
Are there any rules for bumping on this forum ? I searched but couldn't find anything.
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
Temperature gradient in FLUENT abhi084 FLUENT 0 December 4, 2015 06:27
BC in which to set gradient for, or access, different species Y Athanassios OpenFOAM Programming & Development 0 April 1, 2015 11:06
How to access gradient near the boundary for Navier slip bc? Marc10 OpenFOAM Programming & Development 4 February 13, 2014 08:51
Remote Access to FLUENT Doug O'Brien FLUENT 0 December 20, 2004 03:00
