Pressure inlet vs outlet position, transient, time dependent pressure and gravity |
February 6, 2016, 11:19 |
Rep Power: 11 |
Hey,
This is actually a transient multiphase vof case but that fact doesn't change anything about the problem, so I'll post it here. I have a case in which I have a fluid domain with one pressure outlet and one pressure inlet, otherwise walls. I'm using a time dependent gravity as momentum source term in cell zone conditions and a time dependent pressure profile for my inlet boundary. At t=0, pressure inlet = pressure outlet = 0 gauge pressure. Eventually pressure inlet will have a value higher than zero --> therefore it should be pressure inlet. However, due to gravity(t) I will eventually get flow in the "wrong" direction across pressure inlet and outlet. What this means is that fluent will tell me that I have a lot of backflow across pressure inlet and pressure outlet. Will this be a problem for fluent, or can I ignore these messages? Is there a logical error in this setup? I must have a pressure difference between pressure inlet/outlet and I will get flow in +y axis after a while due to gravity and through this backflow. I do not know about mass flow or velocites (these are subject of the simulation). edit: In fact due to phase oscillation I may always have backflow. I'm actually pretty certain that it doesn't affect fluent in terms of getting a bad simulation (other than false velocity vectors of backflow volume fraction) but I'm worried that it will affect convergence bahaviour and therefore will add to computing cost. Is this true? I could potentially move to a closed system setup and live with its drawbacks. Last edited by silent2608; February 6, 2016 at 12:56. |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 11:08 |
Gravity Casting: Pressure Outlet vs. Stagnation Inlet | joeballer | STAR-CCM+ | 2 | May 29, 2014 10:28 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 09:07 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
