February 6, 2016, 01:17 |
I am doing air compressor analysis
I modeled a surface model of air compressor in ICEM CFD and doing unstructured meshing tetra+hexa mixed in ICEM CFD. when I take the .msh file to fluent following BC I am giving inlet BC- mass flow inlet (0.5 kg/s) outlet BC - pressure outlet (back pressure 3.5bar) compressor walls - wall BC with ambient temp the mesh is very complex as the screw inside the air compressor makes it complex and there are much more elements in my mesh When I run the solution with laminar model and energy eq ON it runs for few iterations I get reversed flow in pressure outlet also I get temperature limited to 1.0000e1 warnings during iteratins later it diverges because of the temperature Kindly anybody can help me to get solution would under relaxation factor help in this regard? Thanks |
Data Center Air conditioning Boundary Condition problem | jaypatel | OpenFOAM | 9 | April 8, 2020 16:04 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
Simulation of air flow in a chamber | Issa | CFX | 3 | November 23, 2009 18:16 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 08:04 |
