February 3, 2016, 02:56 |
Unsteady flow around a building
LKKKK
Rep Power: 10 |
Hi Everyone.
I have problem in simulating unsteady flow around a super tall building (300 m ). The main problem is the building is like a tower .See the image in attachment. I am using Ansys fluent 16.0 and I used the Hexmeshing and got the skewness for body mesh as 0.849 (acceptable). I am fine upto this. The Real problem comes in Solving part. I mean what reynolds number I should use for this building(Please note that it is not like a cylinder problem where u just choose reynolds number for whole geometry) ? How do I choose reynolds number at different parts of my geometry( I have 70m diameter cylinder at bottom and 15 m all the top and then sphere of 25m dia at the very top)? My domain size in mesh is ( 1750m from inlet to building, 5250m from building to outlet ,2100m from building to top ) . I defined inlet,oulet,and wall functions for topsurface,ground and building in my domain. Please help me with following questions? 1. What reynolds no. should I use for different parts of my model and how should I apply as a whole? 2.What model should I use ( Laminar or (turbulence since I have super tall building and large domain )? 3.what courant number Should I use? 4.I am defining wind profile by own ,will it create any problems? 5.I can calcaulate timestep once I calculate strouhal number. but again I need Reynolds number to calculate strouhal . Please help me if I miss any significant step in my modelling process. Thanks a lot in advance. |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 06:36 |
Unsteady interna flow | yhoarau | OpenFOAM Running, Solving & CFD | 2 | June 5, 2012 11:42 |
Unsteady simulation of flow past wheel | Tom | FLUENT | 8 | January 18, 2006 11:54 |
Unsteady Boundary Layer Flow | Wen Long | Main CFD Forum | 0 | July 30, 2002 00:08 |
