Profile question
Old   January 27, 2016, 12:27
Default Profile question
Kegan Leckness
KeganLeckness is on a distinguished road
I've applied an experimental waveform to a pressure-inlet using a profile. I then monitored the maximum pressure on that boundary. My input profile has a maximum pressure of 80 kPa, meanwhile my monitor says the maximum pressure is 65 kPa.
The monitor and input waveform have the same shape, but have different maximum values for the initial peak. Why might this be? My thinking is that the input values should be identical to those monitored.
Thanks
KeganLeckness is offline   Reply With Quote
Old   January 27, 2016, 20:23
D.B
DB
D.B is on a distinguished road
Is your entire profile displaced by 15kPa ? Check your reference pressure and cross check if you are applying and evaluating the same( reference/absolute)
Cheers,
-D.B
D.B is offline   Reply With Quote
Old   January 28, 2016, 16:15
Kegan Leckness
The 15 kPa difference was only at the peak of the waveform. What happened was I was monitoring static pressure, instead of total pressure. Thank you for your response.
Kegan
Unsteady Boundary Profile with data file Arianna FLUENT 34 July 29, 2019 16:35
problems orientating profile Ralf Schmidt FLUENT 1 March 30, 2014 10:00
How to apply an outlet velocity profile to another inlet? siw FLUENT 4 April 10, 2013 11:19
Porosity profile, dividing a zone, or getting zone location from zone khoopes FLUENT 0 June 2, 2012 19:39
Associating profile files for the UDS though a UDF Bharath FLUENT 0 December 1, 2006 15:58
