How to calculate the torque in transient Ansys Fluent |
January 25, 2016, 12:34 |
Ronald Thompson
Rep Power: 11 |
I am trying to determine the optimum angle of attack at each position for a VAWT turbine for a certain airfoil, I want to export the torque at each time step of my transient analysis for the entire rotation. I am using fluent 14.5 A similar question was asked in the CFX forum where someone commented "I would export the torque versus time history To get the full time history, make a monitor point set to torque_x/y/z()@location and then export this point in the solver manager" it was recommended I repost here. I tried creating a monitoring point and setting the expression as stated above in the calculation activities in fluent but when I run it is says invalid command what am I doing wrong? have you to use a different approach in fluent than CFX? Thanks |
January 26, 2016, 10:44 |
How to calculate the torque in Ansys Fluent
Radwanma
Rep Power: 12 |
Hi all,
I have built a full wind turbine model but I have problem when I run the model in Fluent I have not got right Cm ( torque coefficient) values ??? Can someone give me a piece of information or any advice about that, please ?! Thanks, |
January 26, 2016, 12:28 |
Ronald Thompson
Rep Power: 11 |
are you doing 2d/3d analysis? make sure you have set your reference values correctly |
January 27, 2016, 05:10 |
Radwanma
Rep Power: 12 |
HI Ronald,
Thanks for quick response. I have built a 3D model as shown below but Cm values still low !!!!! |
cfx, fluent, monitor points, torque |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Using FLUENT transient data in CFD-Post | GJC075 | FLUENT | 0 | November 25, 2013 09:56 |
Results are different for Ansys Fluent 14.0 and Fluent 6.3 | syavash | Fluent UDF and Scheme Programming | 1 | February 17, 2013 01:09 |
Transient FSI heat transfer using FLUENT and ANSYS | kevpw | FLUENT | 0 | March 26, 2010 16:04 |
