January 25, 2016, 04:27 |
Ansys Fluent results issue
Robin Johny K
Hello..
I wanted to analyse the flow around the NREL S822 and S823 airfoil for wind turbine blade design purposes. It's a 2D analysis and i used the C mesh style. I tried analysis through various models, ranging from inviscid to Reynolds SST, basically the whole thing. I'm a bit new to ansys, so i didn't change any values in any of those models. Anyway, the issue is, the Cl and Cd values that i get from the analysis, are almost 90% less than the experimental values (using the k-epsilon model with enhanced wall function). The crazy thing is that, the difference of 90-95% seems stable across a large number of Angle of Attack. The next issue is that, even after the flow seperates as the AOA increases, the lift seems to keep on increasing. Only if i can get the Fluent results approximately equal to my experiential results, can i proceed further in my project. Please help me out here. What should i do to correct all these ?? |
ansys, aoa, fluent, lift, model |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
Fluent results export to ANSYS Classic | sunlin | ANSYS | 2 | September 16, 2015 02:55 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 12:07 |
export data from fluent to ansys | galapago | FLUENT | 0 | August 4, 2010 14:04 |
Exporting temperature results fro fluent to Ansys | vinay kulkarni | FLUENT | 1 | February 21, 2007 03:31 |
