January 24, 2016, 06:21 |
moving wall profile file
mohamed samy
Rep Power: 12 |
Hi there,
I am trying to simulate 2D piston movement i searched online and i got that i can make it with profile file so i wrote this file *the moving wall called piston piston 2 11 0 time x 0 0 1 -0.01 2 -0.02 3 -0.03 4 -0.04 5 -0.05 6 -0.06 7 -0.07 8 -0.08 9 -0.09 10 -0.1 but when i read it in fluent it not added to profiles and it says "Reading profile file..." and not doing anything so what is the error is it in profile file or on how i add it or what ??! |
January 24, 2016, 10:29 |
mohamed samy
Rep Power: 12 |
I found a solution the right way to make it work
piston 11 2 0 time x 1 0.1 2 0.09 3 0.08 4 0.07 5 0.06 6 0.05 7 0.04 8 0.03 9 0.02 10 0.01 11 0.0 but i have another problem after starting the solution before any iteration it gives error "Update-Dynamic-Mesh failed. Negative cell volume detected." so what should i do ?! |
January 24, 2016, 17:10 |
Rep Power: 18 |
It's likely you're moving the piston too far in each time step (causing a negative volume in a single cell). Try reducing the time step of the moving/deforming mesh and/or increase the number of mesh updates per time step.
January 24, 2016, 17:41 |
#4 | |
mohamed samy
Rep Power: 12 |
"Update-Dynamic-Mesh failed. Negative cell volume detected." when i press calculate or when click on preview mesh motion how to increase updates per mesh ?! sorry i'm new in CFD |
January 24, 2016, 17:46 |
mohamed samy
Rep Power: 12 |
i believe the problem may be wrong in profile file or in the way i setup the dynamic mesh settings
the motion of the line is working right but i want to ask in a thing in profile file i just wrote the position of the left line (piston) at each time step only should i change the length of wall and axis (upper and lower line) too or the program understand that or what ? |
January 25, 2016, 04:59 |
mohamed samy
Rep Power: 12 |
the white vertical line is piston so with its movement the horizontal lines (wall and axis) length not change is that what causes the negative volume problem if so how to overcome this problem should i wrote that in profile file or what please anyone help
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 18:25 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 14:14 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
