January 21, 2016, 10:07 |
fluent error
phani
hallo
I created mesh for a inlet geometry. I have given following boundary conditions inlet pressure farfield outlet: pressure outlet ; Cowl and diffuser as wall but when i read mesh file into fluent it is showing "Flow boundary zone 15 is adjacent to a solid zone (11). This problem MUST be fixed before solution can proceed!". Can anyone tell me what is the error and how it can be solved? |
January 21, 2016, 12:02 |
Lucky
Rep Power: 66 |
It's a problem with the the Fluent interpreter of your mesh, which means something is wrong with the mesh. Usually it's because you try to specify the boundary condition or zone types strangely in the mesher and then import into Fluent. What mesher are you using? It's much less error prone if you simply make everything walls and fluid zones and then specify them in Fluent rather than trying to copy them over.
January 21, 2016, 12:08 |
phani
I am using icem cfd
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 08:43 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 06:34 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
