gas turbine combustion chamber cold flow simulation |
January 21, 2016, 07:26 |
chetan chawane
Dear all,
i am chetan working on the project title of gas turbine combustion chamber simulation. i have set following parameters in fluent for simulating the flow 1.solver- pressure based and steady 2. standard k-ep model 3. material- air ideal gas law 4. Boundary condition- inlet-mass flow B.C, outlet- outflow B.c inlet mass flow rate varies from 0.253 kg/s (Re=87000) to 1.6 kg/s (Re =550000) please find attached Results at Re=87000 now i want to use density based solver for higher Re because mach no goes above 0.3 but the solution is not converge and which B.C should i use because ouflow B.C is not suitable for density based solver |
January 21, 2016, 11:56 |
Lucky
Rep Power: 66 |
Try a pressure outlet boundary condition (with target mass flow rate if needed).
Setting up proper initial conditions helps the density based solver tremendously. Try using the solution from a pressure based solver to setup the density based solver. |
[ANSYS Meshing] Aspect ratio of 3D simulation of flow over turbine with k-omega, SST | TKP | ANSYS Meshing & Geometry | 0 | October 8, 2015 12:26 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
air flow simulation in gas turbine enclosure | Frankie | FLUENT | 2 | December 28, 2001 23:54 |
Combustion Flow Simulation in the Incinerator | Jin Wook LEE | Main CFD Forum | 5 | July 26, 1999 21:07 |
flow in gas turbine | Abdul Hafid | Main CFD Forum | 1 | September 14, 1998 10:39 |
