Sebastian Arpke
Rep Power: 0 ![]() |
Hi all,
I am modelling a steady state case for a cavity between two rotating turbine disks. I am using the SST k-w-model and the pressure based solver. There are multiple mass-flow inlets into the cavity and four outlets out of the cavity. All of the outlets are pressure outlets from which one is specified with a target mass flow rate. After running the case for a while I switched two of the remaining pressure outlets to target mass flow rates too. I did this one after the other to let the system stabilize for a while. Now I have the problem that the two biggest inlets (equal in mass flow) show more than double the inlet mass flow to what I specified and according to this the pressure outlet has double the oulet as well. I have no clue what might be causing the problem. The problem occures more or less from the beginning of the simulation. Thanks for your help! |
Two Mass flow inlet bc convergence problem | nabidinhomessi | Main CFD Forum | 5 | December 14, 2015 07:11 |
Flow not moving - Supersonic/Initial Pressure problem? | shankara.2 | FLUENT | 0 | June 9, 2009 20:49 |
steady RANS for flow problem with unsteady inlet? | kat | Main CFD Forum | 0 | February 16, 2009 10:24 |
Problem on boundry of two phase flow | youngan | CFX | 0 | June 30, 2003 02:32 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 17, 2003 19:23 |
