DEM Collision contact force
Old   January 20, 2016, 21:10
Default DEM Collision contact force
S. Morichika
Saidul is on a distinguished road
Hi All,
I am considering particle-particle interaction in DPM. In DEM collision settings there are different contact force laws. I am using Spring-dashpot laws for normal and Friction-dshf laws for tangential direction. I am having problem to define the constant value. I am simulating micro particle(inert particle) ranging form 1 to 10 micro. Can anyone tell me how to modify all of the constant value? Please see the attached image.
In my case, when two particles will collide, it will reflect from each other.
Thanks for your time and help. Thank you very much.
Regards,
Saeed;
Saidul is offline   Reply With Quote
Old   January 25, 2016, 03:23
S. Morichika
Can anyone tell me the spring constant value for 10 micro spherical particle for spring collision model. In FLUENT the default value is 1000 for both spring and spring-dashpot model. are the spring constant values are different for different size particle and different flow rates?
Thank you very much for your help and best regards,
Saidul;
Old   July 20, 2022, 05:23
Default Follow up
E.D.
Enno is on a distinguished road
Hello, did you find an answer, because im simulating particles collision in almost the same size and cant find a lot on dem.
Thank you
Enno is offline   Reply With Quote
dem collision
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
DEM collision error Clarence91 FLUENT 0 July 17, 2014 19:28
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 14:58
Force can not converge colopolo CFX 13 October 4, 2011 23:03
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 11:25
