January 19, 2016, 05:21 |
Gas bubbles in water tank
Vishnu
Rep Power: 11 |
Hai all,
I am modelling air bubbles in a water tank. The air is injected from a small orifice at the base of the tank. An unsteady simulation is done in Fluent using VOF method. The orifice size is 10 mm and the water head is 0.25 m. When simulation is being done, the air phase is getting attached to the base and growing to a size of about 30 mm before it detaches and starts rising in the liquid. That a big bubble for such a small hole is not possible. Can any one suggest me how to tackle this issue. |
January 20, 2016, 22:35 |
Rep Power: 13 |
check your settings for the surface tension maybe?
vof |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 15:27 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Simulating a tank filled with water and injecting vapor into it | belkadi | OpenFOAM | 3 | May 24, 2013 05:43 |
Gas flow profiles in mixing tank | srinivas | FLUENT | 0 | November 8, 2006 05:52 |
modeling spilling of water from a tank | jemteo | CFX | 6 | June 25, 2006 20:33 |
