Thrust of a pipe flow
Old   January 18, 2016, 12:50
Default Thrust of a pipe flow
a m s
Easyqus is on a distinguished road
Hi
I have an unsteady pipe flow (sinusoidal velocity profile) which outputs into a large domain. The geometry is specified as 'axisymmetric'.
I want to measure the thrust of the jet a short distance downstream of the pipe exit, how can I do this?
I know I can monitor the pressure, velocity and density at a range of monitor points and then put them in a momentum balance equation etc. but the only way I know how to do that is setting up parameter points at each monitor point individually. Say I had 20 monitor points, that would create 60 output files to then process which isn't ideal. I have tried using a 'rake' but am unsure what data that is outputting as it only outputs one value for the whole 'rake'. Would I use integral, mass-averaged, area-averaged?!?! And how would I then calculate the force for fully revolved pipe?
I know there must be a quick and easy way to do this and I have tried looking but it either outputs 'zero' or I'm not certain what it's outputting (and hence how to interpret the value!)
Any help would be hugely appreciated, thank you.
Easyqus is offline   Reply With Quote
Old   January 20, 2016, 03:32
Lucky
You could create a function, either a custom field function or a UDF for the stream thrust and then you could integrate this stream thrust.
monitor, output, pipe, thrust
Plotting of Graphs of Reynold Number Versus Length In Counter Flow Double Pipe in CFX Shomaz ul Haq CFX 1 January 4, 2016 13:16
Setting boundary conditions for simple pipe flow with flow direction changing in time Sipher FLUENT 1 May 4, 2015 21:05
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 12, 2012 00:18
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 21:41
Pipe Flow Saima CFX 1 January 10, 2011 17:41
