NOx calculations slow to converge - faster method? |
January 16, 2016, 05:40 |
Antonio
Rep Power: 10 |
Hello, I have been performing this simulation on a combustor for a while now and I noticed that after 8000 iterations I have the convergence for all the quantities but the NOx, which I predicted (knowing their order of magnitude and the calculation speed) would converge after approx, 400000 iterations, also according to a previous work which had the same amount of iterations, give or take.
Since this would take entire months, is there a faster way, even less accurate, to calculate the NOx? (PS. I have deactivated all the other equations after their convergence in order to make calculation faster, but even with that, you can see from the above predictions that is too slow ) I am running a pretty standard simulation, k-e model, species model with liquid fuel and cone atomizer, transient (need to wait 8000 iterations for convergence to be reached). A big THANK YOU for your help! |
atomizer, cfd, emissions, fluent, nox |
Newton's method failed to converge | Mohan | CFX | 7 | September 23, 2020 06:50 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
Newtons Method failed to converge in 100 iteration | hagupta | CFX | 9 | December 2, 2010 06:41 |
Code for most powerfull FDV Method | D.S.Nasan | Main CFD Forum | 6 | September 4, 2008 02:08 |
Slow convergence in steadystate incompressible simpleFoam suggestions | brooksmoses | OpenFOAM Running, Solving & CFD | 0 | March 3, 2006 04:57 |
