Boundary condition for Progressive cavity pump
Old   January 15, 2016, 09:14
Default Boundary condition for Progressive cavity pump
Mrinal K R
MrinalKR is on a distinguished road
Can anyone please tell me what boundary condition be use for a progressive cavity pump (PCP)? I am using Ansys Fluent and dynamic mesh method is used for rotor movement.
I tired with pressure inlet and pressure outlet boundary condition, but the discharge at outlet is getting positive value ( the value was not matching with experiment). Other boundary condition such as mass inlet and pressure outlet also tried, but required pressure (experiment value) not generating.
You can see the animation of PCP here https://www.youtube.com/watch?v=jRC_O7hQBgc
MrinalKR is offline   Reply With Quote
Old   January 22, 2016, 04:16
Mrinal K R
Can anybody please reply?
Old   September 6, 2016, 11:41
Default Progressive cavity Pump
Fahd Mohamed Elabd
Fahd is on a distinguished road
Send a message via Skype™ to Fahd
Hi Marinl,
I am working in PC pumps CFD simulation, I could generate structured mesh using ICEM. I stuck in fluent remeshing. I have a UDF for rotating the rotor inside the cavity using DEFINE_CG_MOTION function but updating the mesh did not work. once I got negative volume detected, and once I got a left hand elements.
If you could help me with mesh motion.
I saw ur post, How did you solve the B.C. problem with ur model
best regards,
-Fahd
Fahd is offline   Reply With Quote
Old   September 6, 2016, 12:47
Mrinal K R
Hi Fahd,
You have to use unstructured mesh for mesh movement and use spring based smoothing and remeshing methods in the dynamic mesh model. If possible try the PCP model kinematics in solidworks or any modeling software and confirm that rotor is not touching the stator wall.
Regards,
Mrinal
Old   September 7, 2016, 04:42
Fahd Mohamed Elabd
thank you alot, I will try and let you know.
Best regards,
-Fahd
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
Centrifugal pump boundary condition Mohankumarg12 FLUENT 2 August 9, 2011 01:04
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 12:32
