May 12, 2018, 08:05 |
Thanks
#21 | |
Tom
Rep Power: 8 |
October 12, 2018, 08:55 |
#22 | |
Rep Power: 12 |
The tutorial model in ansys, if u run it standalone, then u ll be getting high temperature in the cell/active material. However, if u try to increase the discharge rate of current and try it, it should provide high temperature in tab components. ANd also the parameters used in the Defauls are for that specific model. If you change the geometry, then even the temperature development would also differ. Try to run an charge case with high current in the range of 2-3C's, then you may get it easily. Regards VK (Gokul) |
August 14, 2019, 08:39 |
#23 |
Rep Power: 7 |
Can anyone share the model with me? Thank you. dylanme@sina.cn
battery model, battery pack, fluent |
Electric mesh and thermal mesh in battery module | sandeep7681 | STAR-CCM+ | 0 | January 13, 2015 23:39 |
Terminal Connections Battery Module | kanny | STAR-CCM+ | 2 | July 31, 2014 00:40 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Fluent Fuel Cell Module Tutorial - Error!!! | shamsnoor | FLUENT | 6 | August 7, 2012 07:30 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 21:51 |
