Issue with layering
Old   January 9, 2016, 17:47
Exclamation Issue with layering
Kishore Ranganath R
kishoreranganath is on a distinguished road
Hi all,
I'm trying to simulate a liquid piston model. Water is being used to compress air in a chamber. There is no intermixing between the two fluids, and hence i did not use VOF (hope that is correct!). Now, I want to see how a solid body floating on water would affect the process. I have run few experiments and have the results with me. But, I'm not able to model the same. Please find attached the image of the setup I created on WB.
In the image, zone 1 is where the water enters and pushes the solid surface to compress air which is present in that chamber. I tried using a UDF, but that did not work. When I ask for motion preview it says that the solid in the middle has no surface.
The UDF that I used:
#include <udf.h>
DEFINE_CG_MOTION(vel_liquid_piston, dt, cg_vel, cg_omega, time, dtime)
cg_vel[0] = 0.005;
cg_vel[1] = 0.0;
cg_vel[2] = 0.0;
NV_S (cg_omega, =, 0.0);
Kindly help me with this simulation!
Thanks in advance!
kishoreranganath is offline   Reply With Quote
layering, piston, udf
[swak4Foam] swak4Foam 0.3.1 OF2.2.2 Installation Issue scnsc OpenFOAM Community Contributions 3 August 20, 2014 08:59
Strange issue while launching ANSYS workbench in CentOS 6.4 Philip_C ANSYS 11 August 29, 2013 07:44
CyclicAMI Issue In OpenFOAM 2.2.0 prasant OpenFOAM Running, Solving & CFD 17 March 16, 2013 03:00
Pressure boundary condition issue Vijay FLUENT 0 April 6, 2012 14:35
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 09:27
