Interface Creation For Sliding Mesh Using Cutcell Meshing |
January 9, 2016, 06:34 |
Hello everyone in the Forums,
Iam trying to simulate for my master's thesis the flow around a 3D HAWT using Fluent. I have used the Single Rotational Frame Method, but i cant seem to get the right results. Iam trying to simulate the rotation of the blades using the Sliding Mesh Method. However, because of the dirty CAD Geometry i have, (which CANNOT be further fixed) i have to use cutcell assembly meshing. Assembly Meshing produces a conformal mesh between the 3 fluid bodies i have created in order to rotate the middle one which contains the blade. As a result i cannot "see" the mesh interfaces between the 3 bodies (2 interfaces between the front and the middle and 2 between the middle and the rear. I also have turned Create Shared Topology option in DesignModeler to 'none'. How can i get over this? Any ideas would be very appreciated. |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Frozen Rotor 1:1 Mesh Connection | pharley | CFX | 5 | January 31, 2013 17:15 |
creation of mesh for boundary layer in Fluent Meshing Tool | fferroni | FLUENT | 2 | December 8, 2011 06:05 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
