set different viscous resistance simulating flow through an anisotropic porous medium
Old   January 5, 2016, 11:11
Lightbulb set different viscous resistance simulating flow through an anisotropic porous medium
Maria Chiara Palumbo
m_chiara_palu is on a distinguished road
hi everybody, i'm trying to simulalte the flow through a bundle of fiber (they are deposed parallel to each other, but they have a different inclination alternatively layer by layer ). as the bundle is an anular cilynder, I was trying to use the conical/cilyndrical coordinate, setting the option for the porous zone. (so i'm considering the bundle of fiber as an anisotropic porous medium)
What i have actually is the value of the viscous resistance in the radial direction, in axial direction, and also in a direction of 30° and 60°(depending on the angle at which the flow pass through medium i have a different viscous resistance). so I have four different values of viscous resistance. I was wondering if there is something that I can do to solve this problem.
Using the conical/cilyndrical coordinate system in fluent, I can set three different values of viscous resistance, respectively for : axial, radial, and circumferential direction. the problem is that I don't have the value for the circumferential, and i have more values in more than one angle. hope I've been clear.
thanks in advance
Chiara
m_chiara_palu is offline   Reply With Quote
anisotropic material, anisotropy, cylindrical coordinates, porous media, viscous resistance
Porosity and viscous resistance in porous media Tanjina FLUENT 0 August 2, 2015 14:02
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Porous Medium & Mass Flow Rate NewMY FLUENT 4 November 26, 2009 03:26
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Simulation of incompressible flow in porous medium Jack Main CFD Forum 7 February 16, 2000 12:27
