Heater inside a closed chamber
Old   December 21, 2015, 02:56
Post Heater inside a closed chamber
Maharashtra
iamjnd is on a distinguished road
Attached jpeg image shows my query.As shown in the image there is an electrically operated heater inside a closed chamber. The heater is heated up to temperature of 150 degree Celsius. I would like to know
1) The effect of heat radiated by heater around the chamber/enclosure.
2) Where will be the maximum temperature and where minimum around the enclosure.
Please suggest me how should i proceed. I am using Ansys fluent and CFX to perform the analysis.
iamjnd is offline   Reply With Quote
ansys fluent 14
[snappyHexMesh] SHM error: inside mesh not possible Naresh yathuru OpenFOAM Meshing & Mesh Conversion 1 January 11, 2017 00:58
Give comment to a heater inside the model ahvz Fluent UDF and Scheme Programming 14 September 23, 2015 03:00
[Other] How to define internal walls for injector inside a combustion chamber by OF2.1.1 with sandy13 OpenFOAM Meshing & Mesh Conversion 0 May 22, 2013 07:59
heat transfer analysis inside the closed roam san FLUENT 0 March 3, 2006 07:26
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
