The problem in modeling the oxygen concentration is flow water
Old   December 17, 2015, 09:51
Default The problem in modeling the oxygen concentration is flow water
志新高(Zhixin Gao)
zhixin is on a distinguished road
Hi, everyone.
I been working on the concentration of oxygen in flow water contained in a elbow pipe. And I use the species transport and k-e turbulence model.
I assume the inlet is velocity-inlet, and assume the oxygen concentration is saturated(4.84e-06)
The questions is when I finished the computation and check the contours of mass concentration of O2 in wall and int_fluid. It seems like the oxygen concentration didn't change at all.
At first I thought when the water flow through the elbow. The pressure's change and the turbulence will lead to the diffidence of oxygen distribution. So anyone can tell me if I was wrong during the modeling process or the results is right.
Thanks a lot.
zhixin is offline   Reply With Quote
Old   December 18, 2015, 06:16
Cees Haringa
CeesH is on a distinguished road
If you are feeding a saturated oxygen solution, why would the oxygen concentration change? As long as there is no consumption, there doesn't seem to be a reason why it should. What are the physics related to oxygen transport and consumption/production in your model?
Best,
Cees
CeesH is offline   Reply With Quote
Old   December 18, 2015, 07:45
志新高(Zhixin Gao)
Originally Posted by CeesH View Post
Best,
Cees
Thank for your reply.
I read a paper about modeling the corrosion in the pipe(use the oxygen diffusion to express the corrosion degree and the oxygen is consumed totally at the wall boundary by reacting with metal iron such as Fe).
Your reply reminds me to set the oxygen concentration at wall to be zero. But I don't know if it works.
Old   December 18, 2015, 08:13
Cees Haringa
I have no experience in that field, but it seems to me you will need to set some reactive boundary condition or so; check the wall boundary conditions for species and the surface reaction model. You will at least need to specify some physical model by which oxygen can leave the domain, either via consumption or by transport through the wall. Lacking such a model, your oxygen will only move, but as the concentration everywhere is equal there will be no gradients whatsoever.
Old   December 18, 2015, 08:19
志新高(Zhixin Gao)
Hi Cees,
I'll try it later. Thanks
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 10:36
Problem in modeling 2D Couette flow shantanu Main CFD Forum 14 July 20, 2017 14:37
modeling of flow in porous where water level is below the top of the aggregate level Tanjina FLUENT 0 March 23, 2014 16:07
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
