Coupled wall for Interface/External Flow pass through internal flow
Old   December 16, 2015, 15:15
Default Coupled wall for Interface/External Flow pass through internal flow
Onur
Onurozcan is on a distinguished road
I run across problem that is external flow get through/pass through tubes(internal flow)
Someone advise me not to be neccessary to specify coupled wall in interface.
But external flow get through internal flow(tubes)
Someone can help me what should I do?
I think that coupled wall separate both internal and external flow
https://imageshack.com/i/p8ErVyMZp
and there is no flow in upper right in system.Are there any informations about it?
Kind Regards,
Onurozcan is offline   Reply With Quote
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall sebastian OpenFOAM Meshing & Mesh Conversion 6 October 21, 2010 05:36
heat flow UDF on coupled surface (wall-shadow wall) Friedmann Fluent UDF and Scheme Programming 0 August 5, 2010 11:25
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Flow Visualization of impinging swirling flow on the wall. sangaria Main CFD Forum 2 March 26, 1999 14:31
